It doesnt connect, I have to patch that link.
But since it changes the file size and breaks it, we are at a dead end.
Iām sending the file so someone can try to patch it.
We should make another thread about this
If someone can figure it out
The devs maybe
Lemme make the thread
you fixed the thing? @HyperTerminal95
I made this post (i have credited you)
Nope, its breaking. Iāll hold the project for now, Iāll be going soon.
Either you have your hex editor on insert mode (overwrite is useful for these kinds of situations), or the URL youāre patching it to is wrong.
Can you try patching this? https://archive.org/download/MsnMessengerClients2/Windows%20Live%20Messenger%208.0.0566.0%20(English%20-%20United%20States).zip
weād be thankful a lot if you happened to fix it
When I patch it normally it connects to NotRST and sends the token, but it immediately crashes afterwards, similar to WLM 2009, so thatās a no go for now. However, like WLM 2009, when I make it connect via RST.srf (looped back to my local server), it doesnāt crash. This time, it stays on the signing in screen for some reason, so I know that the server doesnāt send something this build of 8.0 expects. Iāll go look into it soon.
halp
@omegabr same thing. part of the beta.
(fuck that bump)
The error (SIDEBYSIDE) or like this:
is actually the Manifest inside the exe file is invalid, I copy an WLM 8 exe Manifest one and itās working, You have to modify using Resource Hacker.
I fixed MSN 6 by doing this and WLM 8 Beta might work.
pics:
Use Universal Extractor ffs
what version is?
