I would like to change the wlm 2009 pub
This to this
This is replaceable in msgsres.dll using your favourite resource hacker tool, it’s under 4000\1472.
I updated the image to fit and here’s the updated DLL, download and move/replace into the \Program Files (x86)\Windows Live\Messenger folder.
Edit: Here’s another version of msgsres.dll with the 2012 version of the image.
Thanks! Jonathan ![]()
Can we get ads that are made by us on here?
What did you have in mind exactly? I assume you mean more than just changing the image in the DLL.
Will we get custom ads working on this server, that’s what I mean.
You’re the best, Jonathan! thank you
Yeah thank you x1000 bro ! You’re always there when we need you
Nice, I just tried right now and I saw it! Thanks for telling us how! I, at first, thought it was in the PNGs or the BMPs without telling us that.
As to the OP: Didn’t expect you to get the styled WLM 2009 ad pic but thanks anyway.
Yes, that’s veeeeery true.
Thanks, I really appreciate it and I try my best
That said, I wouldn’t have any reason to bother if you weren’t here, so you can thank yourselves too ![]()
Also, when I was making this for Francis, I compared it to the 2012 version of the ad window, which is slightly different:
So here’s another version of msgsres.dll with that one.
You’re welcome, and I appreciate the best work.
Ok, if you say so.
Yeah, it’s beautiful, except there’s no windows icon, but i love both, the 1st one is my favorite, but i still love both pics. Thanks for providing this really. I love it.
The size is correct, but the display seems to be broken in that version of Resource Hacker.
The author has put up a new version to fix the issue.
A version without extra text or images, so you can easily add what you want:
Nice image trekie, thanks for providing the source we wanted
Speaking of ad window, do you know the location where are display pictures of WLM 2009 stored in? Bc I forgot. And thank you in advance.
The DPs are stored in a UserTile folder in AppData. To get there quickly, in any Windows version, press
R (Windows Key and R) on the keyboard to bring up the Run box.
Then copy and paste %appdata%\..\Local\Microsoft\Messenger into the box and choose the OK button. In the Messenger folder that appears, choose the folder corresponding to your Messenger e-mail address, then choose ObjectStore and then finally the UserTile folder.
Within UserTile, you’ll see id2 and dt2 files. The actual images are the dt2 files. You can drag and drop these into a browser window to quickly find the one you’re looking for.
I reported the bug to the Resource Hacker developer earlier, and he’s already put up a fixed version. Pretty cool guy ![]()
Cool, also where’s the default display picture located?
EDIT: Nvm, after a little researching on RH 5.1.8, I found it. It’s on 4000 > 582.
