Problem description: it doesnt connect anymore, even using the right protocols
Error code/error message:“failed to connect to MSN Servers”
What has been tried so far: reinstalling the app
Messenger version: Mercury 4.0.2
Windows version: Android 10
lol, mercury it’s super unstable thing
check here
and here
Still doesn’t work
contact with Profile - Mateus_Rick - MessengerGeek
and post back.
Follow the instructions on the second post i have tested and it works!!!
did you follow the instructions from here??
Yep, step by step
I have just tested and discovered that the app only connects with mobile data and it fails to connect with WiFi
@Jose_Tetris can you step in???
go on escargot and change your password.otherwise contact with the developer
Tried changing password and longing in using mobile data. Still no luck
honestly dont know man
mine is working ONLY with mobile data.
try with another mail perhaps?
also add yourself in the discord channel maybe they can help you there.
tried another mail. nothing
ask on the discord escargot channel maybe they can help you there
If Mercury Messenger did not work for everyone, then would have a mistake
Yeah I can’t even set custom ringtones lmao
windows
