Yet another MSN revival
may i get a key?
Sent
It is not public yet
can i get a key too ?
Sent
The first beta version of the web “panel” for Kring has been enabled and can be found at https://nu.kring.im (most likely temporary subdomain until I can find a good name for this “panel”)
You (of course) need an account to use this
(by the way, if you want to edit your profile, simply hover over your name in the navigation bar and links will appear below it)
For whatever reason, the option allowing others to message me was disabled. (I don’t know why, considering I didn’t even know that was an option)
It’s enabled now
Hey so for some reason i can’t change my profile picture. I wanted to try the picture with the stars but i didn’t like it and now i can’t change it… help :stuck_out_tongue:
By the way, whenever i try to log in on windows live messenger 2011 beta, it just says logging in and then takes me back to the login screen. I know it’s communicating with the servers since when i type an invalid name/password it says invalid password. Are there any fixes?
I’ve sent you one now
That happens sometimes, just restart the client and it should let you, if that still doesnt work you can also change your pfp on https://nu.kring.im
Some 2011 betas are “blocked”, if you’re sure your password is correct then it’s probably just “blocked”, I’m pretty sure there are patched EXEs for those specific 2011 betas somewhere but I don’t know where exactly
ok it worked when i changed it in wlm 2009
well, i doubt there are since the offline installers are REALLY rare. It took me a day to find an installer :stuck_out_tongue:
They weren’t that “rare” back then, they leaked on some forums with patched EXEs that let you log in even if you weren’t meant to
Oh, i meant the offline installers.
We should make an custom MSN client with Kring.im support
hi can i have the key?
Sent
I have something to say and a suggestion:
First of all congratulations on actually reviving MSNP21/22!
Second of all I want the invite code so I could try out kring on WLM 2012
Third and last (a suggestion): Support Mercury Messenger on Android with kring ( Mercury Messenger for Android with Escargot support )
Thank you.
