Tbh (in my opinion) mercury messenger is kinda trash. The ui is all over the place, it doesn’t even resemble windows live messenger and it’s meant to be used with old android. Perhaps something like kring messenger could be better?
yes sure, it would support android 1.5+ that specific future custom client
Unfortunately that feature does not work anymore because it was depending on the flash version of YouTube and ActiveX component.
Unless if some developer finds a way to mimic it, or capture the request by dll injection and “render” the video inside the box.
A key has been sent! Mercury Messenger could be supported, it just needs to be patched to go to kring (matter of fact i think any client who used msnp even if it’s using the http gateway should be able to be patched considering all versions of msnp who were used for wlm are now supported on kring)
would it work with yt2009?
Hey just a question, for tweener auth do you have t= at the start of your token? Wanted to see if kring works with MSNTV2 however its picky with tweener token fomat.
If you do I can test if kring works, it should hopefully work if you do have that.
Pretty sure I do yeah! I know MSNTV (or at least WebTV) has specific commands made for it tho, I just don’t know what they are and how they work, if you’re able to tell me what they are I could work on implementing them
Yeah the only WebTV specific command is IMS which is used to disable/enable switchboard access.
WebTV/MSNTV should already work with your server, TV2 might not if you dont have the t= prefix added onto the tweener token for tweener login.
Well i mean it seems to be there lmao, I haven’t touched twn in two years x)
Ah alright, Well just tried it on my TV2 and apparently it hates pprdr.asp due to the fact passporturls isnt PassportURLs
Yeah twn is weird idk sometimes it wants Passporturls then other times PassportURLs…
Yeah it dosent matter, I can just make it change that for me and also it really hates if you have https:// at the start of DALogin as it automatically inserts https:// by itself lol.
I will post a screenshot of it working once I get it working
Ok so funny story, I got Authentication to work but your MSNP server when syncing contacts to my box actually hard crashed my box lol.
I dont know what your servers doing wrong that my box dosent like but when I tried my box on my server it works so I honestly dont know(Was worth a shot anyways).
Huh thats weird
Yeah, If you want I can try to diagnose the bug if you want?
Yeah that’d be great lol, clearly something’s wrong with my server
I don’t know. Probably.
May I get registration key? Thanks ![]()
