it doesn’t even open for me. i use windows 7 home premium 64x
Do you have .NET Framework 4.5?
yes. it installed it when i installed spotinger
Hi, guys! Thanks for support the application. I’m really grateful try to fix the bug but I saw my code and the problem is in the library that connect Spotify with the code. May be it needs an upgrade or something more.
I’ll try to fix it and make it better.
When I can solve the bug, I’ll notify you.
Thanks again.
can you also make the programm for youtube?
Hello! Mmmm… I’m not sure, but in case if this could be possible, I’ll do it
It doesn’t work for me, I have the .NET Framework 4.5 but nothing happens when I try to open it
You can use my application then [Release] WLM Now Playing on Spotify
It is working and you don’t even need .NET Framework to run, it should run on any Modern OS.
