Refreshed and updated my own MSN server
sinon j’avoue j’ai tester son msn 7.5 est il fonctionne bien x)
Mobile friendly site and mobile client
Wanna be tester
j’ai tester faut quand s’ajoute pour voir l’ajout d’amis mec
The first testable version will be there in january
ok je vais le tester en janvier par d’abord l’ajoute d’amis j’ai deja cree un email sur votre site
Application test tool is ready :slight_smile::
The Setup i got it’s MsnMsgs.exe
What is that version?
MSN 7.5:
it’s patched ?
Yes
Is msn 10 compatible win10 if yes send me a video just in case OF THE SETUP
Not tested yet
Si elle marche sur win10 je l’ai testé
After a bit of downtime servers (5 hours) are back on.
i can’t download the installer, can you send it to me?
Hi, can you try it again should be solved now :slight_smile:
I’m now having connection issues.
Also, why does the site mention WLM support?
oh that was roadmap my bad
Hmm, should be up now again
servers are unreliable, also is there a mercury messenger version of omsn?
