Might be the applications fault too. ![]()
oooooooookay
Yeah, you can add yourself
Meh I’ll just go publish it now ![]()
The API will start not functioning when I have applied the changes
API still needs a certificate, hang on.
ok, API has now a certificate from Let’s Encrypt. Have fun
bug: filters don’t work as intended. will fix it tommorow
does it work with MSN 7.5 now? because I tried b4 and it gave me just erros. (well I’m guessing it’s because I use MSN 7.5)
Actually I don’t know what the mininum requirements of Messenger .NET are since I don’t have any information about the COM library.
Server downtime: Sorry for the inconvience but I’m doing some server migration from self-hosting to trexion ![]()
http://craftplacer.trexion.com/pcl/downloads/
There you go.
it’s working for Windows 10, not sure about the others systems though
Yeah development was mainly done on Windows 7 and 10 but not below 7. XP is already lacking support because of the mininum .NET Framework version
Anyone interested contributing with icons? (preferrably in Aero style)
But Craftplacer, I went to your website and it downloaded a Windows 10 “app”, shared it to a friend, and it didn’t work because Windows 7 doesn’t has support for this kind of program you know…
What kind of icon are you looking for? This will be better quality once downsized for windows automatically.
My app doesn’t state any where that it’s made for Windows 10 (it’s compatible with it from .NET 4.5 onward) and also it’s design is based on Aero.
