WOW
rant rant war war
WOW
rant rant war war
all i did was double click the .gadget and its installed
Both of them is original, unmodified, genuine gadget!
The reason why they do not work is that escargot does not support wlm yet!
i know. i wanted them to appear in the gadget menu
bruh, just double click the .gadget file
it worked
rant rant war war
The Live Messenger gadget works with MSN Messenger:
Double-click to show the contact list.
This gadget runs a background process, CenerTCPMessenger.exe, which is safe according to Kaspersky and Panda Antivirus. I havenāt noticed any strange activity, only that it keeps running even when you close the gadget, so install it at your own risk.
Also, you wonāt be able to close MSN Messenger unless you close the gadget first.
livemessenger.zip (170.6 KB)
thatās interesting, i will try it now.
it seems to work, however how do i get the contact list to show up?
Double click on the gadget.
i did, all it does is fade to black and then goes back to idle
i am just waiting on ol corrupt now
never mind, fixed it.
iāve been waiting for 5 minutes olā corrupt. Y U DO DIS
ya know what would be a cool windows xp mod. gadgets
the gadjet is working for me but the contact list is not appearing
double click, be logged in to MSN Messenger (msnmsgr.exe), should work anywhere, just donāt have transparency from the gadget, it breaks it.
doesnt work, it appears offline
i donāt understand i installed the gadget but its not working it appears offline⦠I use Wlm 8.5
