The site in the archive of course is there, but access to the gadget has long been lost …
Looks like i found it!!!
OnlineServicesGadget_v1.gadget.txt (1.0 MB)
Bonus: Messenger gadget
MessengerGadget.gadget.txt (251.6 KB)
I don’t get it.
use the .gadget ext btw it works for some reason
just rename it and remove .txt extension! ![]()
i did, i tryed to login, using escargot = AuthFail, using real = IM STILL WAITINGGGGGGGGG
Well its the original gadget what uses original ms server settings…
Login with escargot id not posibble to real ms server
Login with real ms account not possible because of ms server side update!
I uploaded it to help devs make it working. ![]()
Thank you! But how to install it? It is just txt file
make a new folder, move gadget txt to it,
hold shift and right click, open command promrnt
"rename *.txt *.gadget"
Ok, thanks. Whats happened with your pathed version?
its in my user folder, it was in pictures since i last downloaded to that folder.
so the gadget opens but doesn’t sign in
do i need both files
rename it to what and change the extention to what. sorry if i comment a lot.i am very excited about messenger working again
Well, the original filenames are:
You can simply add them to your computer!
Unfortunately neither of them will work at the moment!
It will only work, when escargot server will support the newer versions of messenger!
cool. i will add them to the gadgets system file though so it looks genuine
don’t have to, just change the exts to .gadget and double click.
i know but i want them to show up in the gadgets control panel
original is very important to me
it does if you double click, it installs it.
