First i tried updating, then i tried reinstalling
In both cases, the result is the same
Oh yeah. I seem to forget to sign it xd . It should be fixed by now, I tried it on my phone
Cool, now it works
we have to completely uninstall the previous version?
I unable to connect to the servers
For now, it is not necessary as long as the old domain continues to point to the new one. when that stops happening, then I imagine if the previous version would have to be removed
The application should be adjusted as in the first post. Since you cannot connect test with the version published by Mateus, this should still work. or check your isp
The first post is blocked for editing.
ask @TReKiE
If you’re unaware, on Discourse-based forums, editing of posts is handled a little differently from what people are used to. Unfortunately, last time this came up, it ended baldy doing it the way the forum is designed, so I’ve just edited it myself. If you’re unhappy with my edits in any way, either I’ll do something else to allow editing, or you can just write the changes below.
Thank you both for getting that fixed.
It can stay like this. The important thing is to find the application working.
can you inter grade the wlm theme like it used to be and also change the name from mercury messenger to windows live messenger like it used to be??? thanks
Sorry por the bump but…
Since the Escargot hosts have been changed again, what changes should be implemented to Mercury? in the case of the official client, the following configuration is used:
server = msnmsgr.escargot.chat
configserver = conf.escargot.chat
What strings should be replaced? then see if you could help us again to encode the new urls please
Will you continue with this project?
In relation to mercury, it is an app that works but cannot be modified much. It currently works but only that.
Occasionally, escargot’s main server address is updated within the app to keep it running. but nothing beyond that.
The strangest thing to me is that it only connects with mobile data with Wi-Fi, it does not connect
weird. possibly it is some configuration of the router or some event precisely with the version of android you use. mercury is a very old app
mine ,with wifi connects,so its something else.
can I Use Leapdroid Mobile Emulator with mercury messenger? does this works?
I guess it works fine. I have used other emulators to test the app
