If seems like you signed off automatically and you canāt sign back on (with 800701f6 or 81000306) look at his thread
@OhHelloThereImTheGuy, explain :\
EDIT: Itās back up. but still
As I type this, the servers seem to be down (the siteās still up though). Iāll see whatās up.
Seems that the server folded on itself in a manner that didnāt involve CPU or RAM usage, which I havenāt encountered in two years. Took a couple restarts but the server seems to be in working order again.
server is shutdown sometime
Thatās not exactly what happens. In most cases we leave the server on 24/7, but because our server hardware isnāt optimized to utilize full CPU power or have enough RAM, the server can slow down or crash and restart. Very rarely do we shut the server down for other reasons, and thatās mainly to do direct database work.
@OhHelloThereImTheGuy The server is offline again.
Heās deleting some account and it requires the server to be down first ![]()
Oh, I see
Wasnāt that account sending lots of trojans? Maybe thatās why itās taking forever
Yup.
iirc sending files is P2P which means it is not stored on the server
For those not already aware, the deletionās all done with now.
Down again!?
@OhHelloThereImTheGuy, thanks very much for the hype
That stat has always been there since at least 1-2 years ago. Right now that just means someone attempted to use Mercury Messenger with the MSNP21 option (it only loads the contact list, but not the statuses or anything else).
Well, the hype train ISNāT that far for 2011 and 2012.
Oof
THE ESCARGOT SERVER IS BACK UP!
This is a clear sentence.
Hmm if the devs should disable msnp21 option and says ānot supported yetā ![]()
Not possible.
Well itās back up ![]()
