I mean in Mercury app, and why?
Excuse me? That is possible, but we never got around to doing it as we thought it wasn’t anything major to look into.
I see.
Let me try MSN Messenger for mac!
BTW, it’s possible to disable it server-side FYI. As I said before no one on the Escargot team bothered to disable it however.
MSN:mac 1.x - 3.0 work from personal testing and second-hand sources as they use protocol versions that have already been implemented. 3.5.1 and above, while using supported protocol versions, don’t work however because their SSL support isn’t even covered by Escargot right now. Hoping we can change that soon though.
AWWW I WAS USING THE POST MSN Messenger 2.0 on MacOS 9.2 WHYYY
2.0 works too. What made you think it didn’t?
I did it all correctly and it still doesn’t work! (I do have Old MSN support on)
