I don’t even have “Use SSL 2.0” - only for version 3.0. I have Internet Explorer 11 installed on Windows 10. I only have Chrome as default browser since I hate Internet Explorer.
Everything about MSN is allowed in Windows Firewall. If I add the link as trusted in Kaspersky Free Antivirus in the Web Anti-Virus settings, the website just loads and loads and loads for maybe 2 minutes. After that it ends up showing a 404 page. If I disable Web Anti-Virus completely, the page returns as 404 immediately.
I know that it dosen’t need a website. But if I can’t even connect to the server through Internet Explorer, then MSN can’t connect to the server either, since MSN uses Internet Explorer as source… or something like that. TReKIE was talking about in his first and second post in this thread. Link to his first post here: Error 80048821 when trying to login to Escargot MSN - #13 by TReKiE
the last screenshot you gave us to look at shows a 404 from the server. that means it’s connected that you are looking at a server domain. you should be fine to sign in. it doesn’t necessarily mean that you would be able to sign in easily. if you are getting a wrong password error then please refer to this topic.
Thank you, but the problem remain, even if I followed that guide for both Windows 10 and Windows XP. MSN 8.5 failed to connect on both operating systems (even if I know that version 8.5 dosen’t work on Windows XP, according to this forum).
The same issue remained on Windows XP after several attempts and minutes. After that, I installed version 8.1 of MSN and got the same problem despite numerous attempts (I gave up after over 50 attempts) and several minutes.
