2009: windows xp, 2010: windows vista, 2011 - present: windows 7, 2014 - 2020: windows 8.1, 2015 - 2019: windows 10
Windows XP ![]()
MS DOS 6.22 on our first family PC, the first PC that was my own ran win 2000 for a short time then updated to XP
In that of 2006 I had my first pc.
Windows XP Pro, 352Mb Ram and Amd atlon (1Ghz)
Now I use a laptop (8Gb Ram, intel core i7 with Manjaro Linux, Windows 10 and Prime OS (Android)
First PC Iâve ever used was with Windows XP Home SP1, some AMD Athlon iirc, 128 mb RAM, 40 gb HDD.
The first PC I personally owned: Windows XP Pro SP3, Pentium 4 Extreme, Radeon 9800XT, 4gb RAM, 80 gb HDD.
My PC now: sysProfile: ID: 195175 - second2050
Windows 10 Pro, Ryzen 7 1700, Geforce GTX 1070, 16 gb RAM, 6.5 tb HDD, 120 gb SSD
Windows XP SP3 Home Edition
I think some ASUS computer with Pentium 4, (I forgot the RAM size), with Windows XP on it.
In 2008 to 2013, we had a LCD and a CRT monitor with a personal computer that had Windows XP, then in a new year when I was 7, I got a HP Pavilion DV6000 Entertainment PC and it doesnât connect to the wireless network and I use a network cable.
Windows 3.1
Windows xp, its the best!
Windows 7, my favorite OS ever made.
xp vista and 7
technically mine was Windows 2000 =P
XP.
Very late to the party, but it definitely has to be Windows XP and Windows 7.
Windows XP was the very first OS I was introduced to, because it was the first time I used a computer, and I filled that thing up with Dora the Explorer trial games from shockwave and wildtangent pretty fast.
I also used Windows 7 a lot after that, and it pretty much became iconic for me.
I even remember installing Windows 10 on my very first Windows 7 Laptop I owned personally back when the Free Windows 10 Upgrade started, and the laptop had a lot of problems after that.
lol itâs funny
mine was xp and still have it, just that i formatted it
(canât edit this one anymore, so i remake itâŚ)
Back then i was born thereâs a PC running Windows XP (SP2, at the time)
Also i use Internet Explorer back then, until switched to Google Chrome, Firefox, Edge Chromium, Opera GX and again to Mypal/Pale Moon-based.
new timeline:
Timeline:
200x-2011/2012: Windows XP Professional SP2 (SP3 installed in 2008)
2013-2018: Windows 7 Ultimate SP1
late 2018: Windows XP Professional, Windows Vista then Windows 7 Enterprise (Second dual boot, 7 only)
2019: Windows 10, 8.1, 7, Vista, XP
2020:
Aero17 M1 (will upgrade it to Escrow build but i had to check the sysprep first, also its startinng to get slow as fuck)
Windows 10 (1909, originally 1809, 1903, installed on Dec 2019) (for my dad)
Windows 8.1 (installed 7-30-2020) (the main one I use and attempting to call it Crystal 8 and mix it with Windows 8 DP (i mean transform to Windows 8 DP, while also use Crystal 8 Aero Glass atlas), failed, got Windows Deactivated and have to sfc /scannow to fix the KMS Activation bug).
Windows Embedded POSReady 7 (installed in June 11, 2020), broke for some reason, and transformed to Windows XP (partially)
Windows Vista (not installed Extended Kernel, installed March 22, 2020), unused since then and might want to reinstall
Windows XP SP3 + POSReady 2009 patches (installed around May 2020)
2020 (second gaming PC):
Windows 8.1 (installed on July 21, 2020), needs to reinstall because Aero Glass wonât run on startup and instead its Queued (checked in Task Scheduler) for hours and its still wonât run.
Windows Vista (installed July 22, 2020)
Specs on my Windows XP (the old one), motherboard trashed.
CPU: Intel Celeron xxxx (200x)
GPU: Intel GMA xxxx
RAM: 512MB (x1)
Specs on my First Gaming PC:
CPU: Intel Core i5-2400 (2011, 3.10GHz, quad-core)
GPU: Geforce 210 (subvendor Gigabyte, 2009, 512MB VRAM), later
replaced by GTX 750 Ti (subvendor MSI, called as N750Ti OC, 2GB VRAM, 2014)
RAM: 8GB (4GBx2 Kingmax)
Specs on my Second Gaming PC:
CPU: Intel Pentium G2030 (around 2013, 3.00GHz, dual-core)
GPU: MSI GT 630 (2GB VRAM, 2012, couldnât update to latest version of driver due to a bug recognizing this card has dropped support in 2015, and the latest driver is in 2015).
RAM: 4GB (taken from old Dell computer from my bro.
my family pc was windows vista but i will say i had more experiance with windows xp
Windows XP Is my very fist OS bescuse my dad have a windows xp gaming pc from 2003 and The next one was Windows 7 i think
