Script Error when logging in
Everytime I long in two script error pop up:
https://www.googletagmanager.com/gtag/js?id=UA-119140043-1
and
https://escargot.log1p.xyz/static/script/langs.js
Also, sometimes when I log in I need to restart the messenger since I´m not able to send messages by clicking enter.
Does anyone knows what these problems could mean?
IE compatibility issues IIRC.
This is from the new Escargot website in the Messenger tabs, as Messenger’s IE control tries to render it using the older IE rendering engine/javascript.
The quickest solution is to download and run this .reg file, and you’ll gain the benefits of having all the tabs work properly too.
Information on how to do this yourself and details are at:
Thanks Trekie! :slight_smile:
Cool, thanks for the fix. Bye bye pesky warnings! hahaha.
