Refreshed and updated my own MSN server
Nice, if you need any support let me know :slight_smile:
One thing: What are all the server URLs that are relevant at this time? Just the one for older clients or is there more?
Updated urls: Older MSN versions - OMessenger MSN Server (omsgr.com)
Only the gateway is currently not working do you need that?
I was gonna take a crack at mercury,unknown if that will be needed,I was just confirming
Created a little stats page to online track status of the server: https://stats.omsgr.com/
hey jeff, i have a problem :frowning:
well, the problem is that i cant register in omessenger
when i filled the info, verified the captha, and clicked register, it takes a while to a blank page
the meaning of that is that the account hasnt been created successfully. can you please fix the omessenger servers? thank you.
seems like the auth api is down
bruh moment
The cluster seems broken will fix ik tommorow
hello.thanks for the project any ideas adding newer msnpx?? like 21??? or making hybrid clients so they can login using the existing login.live.com and using the custom server for contacts etc? thanks.
Everything is working again, currently there are no ideas to implement that
@jeffdev. i have one big problem
the website and auth API was down while i checked the status
can you fix them please?
great regards. kikoabdou.
Up again and changed some things to avoid further downtime in future
@jeffdev do you know why does MSN 4.5 keep login out me after some minutes?
It seems like server’s down again. When I login it doesn’t even show any error message, just stops signing in.
Sorry for late reply solved
