Hello!
I have some issues with the MSN Server. it does not let me login
i tried it with WLM 8.5 and MSN 7.5, but doesnt work.
Does someone know if i have to change a Registry Key?
i would love an an answer
Hello!
What is the name of the error the numbers most likely
and what windows are you in?
It says that MSN cannot log me in because of a wrong username or password.
The OS i used for that is Windows XP
This is the Error Message what i get when i try to login
And obviously i already tried the Guide, that where it its explained but didnt work
You know you have to install the 5,6 and 7 versions only for old pcs. because the MSN version only works in there not in newer PC’s
Do not use newest versions on old PC’s
What Versions do you recommendend for Windows XP?
5,6 and 7 versions
I just tried it with MSN 5.0 but doesnt work either
And 6.0
Is 6.2 also working? if i patch it myself
6.2 is unpatched
I will patch it real quick and tell you if it worked or not here or via MSN
Could you read your msn messages? I’ve just messaged you my email is ducklame951@gmail.com
i alr tried it, didnt work, i gaved it up and now use WLM 8.5 on Windows 7 Ultimate
Is your password over 8 characters? That’s usually the problem.
yeah it has 9 Letters in it so that cant be the problem
