the songs I’m listening to have stopped being shown in my personal message, since I re-installed the windows media player, will I have to download the escargot again?
Make sure “show what I am listening to” is on in the settings
On top of what Eric already told you, the typical reason Windows Media Player music status sometimes appears to randomly stop working is because the Messenger plugin gets disabled when the player didn’t shut down properly.
If you open up the Media Player options, go to the Plug-ins tab and then the Background category, you should see a checkbox to enable it:
Thank you very much! That was exactly the problem!
After 2 months lol
Anyways thank you for dump this post, now my problem is solved as well
