The patching method is outdated, and you need to use escargot switcher.
(and how?)
This is how you do it.
Haha nice try patching this one i got this XD
did you rename sample-escargot.ini to msnmsgr.exe-escargot.ini and changed the mode to msn inside the ini file?
oh ok let me try
but i set the mode to msn
exclude the .ini part if you don’t have hide known file extensions on.
WTF i tried but doesnt work
Try until it works. All betas worked fine for me without any problems.
doesnt work
can you paste in your config file?
error code: 80048823
@icanttellyou how to fix 80048823??
can you copy the switcher config file?
yes
no idea why you can’t connect, but keep trying…
what about this? Patched an 8.0 WLM Beta! (thanks to @Duki) - #68 by icanttellyou
