Hello guys! It’s been a long time since I’ve had an Escargot suggestion relating to MSN, with the last one being the first Escargot suggestion, implementing real Microsoft account usability (for those wondering if that’s still possible, it is still being considered, but @valtron needs more people who can undertake more complex disassembly and debugging, which will take some time), and the second one being a replacement MSN webcam server, which I still need to see if it’s still necessary to put out.
Anyways, I have figured out that OIMs (Offline IMs) are something Escargot can implement, after reading some documentation on it. Initially, I had thought that OIMs were possible already, considering my limited knowledge of TCP/IP, which I am still learning slowly almost by the day. But now that I’ve come to my senses, I decided to pitch in.
I have already addressed the innards of the OIM services on a GitLab issue I replied to, so I won’t go into too much here, but here’s a summary of what goes on with the OIM process:
Receiving OIMs
When you sign in, you will get an MSG MSNP command appended to the usual account settings MSG command that contains XML data holding your stored OIMs’ metadata.
MSN Messenger will retrieve each OIM’s GUID from their metadata XML nodes, then use each in a SOAP request to https://rsi.hotmail.com/rsi/rsi.asmx in which it will return the specified OIM in an SMTP-like format.
During an active Notification Server (NS) session, if an OIM is sent while you’re appearing offline, an MSG command is sent with a condensed version of the OIM metadata that only contains that OIM’s metadata. Then MSN will go back to the rsi.asmx service to retrieve the OIM’s actual message data.
If the total OIM metadata node count exceeds 25, the XML in the MSG command will be replaced with the string too-large. MSN Messenger will then send a SOAP request to https://rsi.hotmail.com/rsi/rsi.asmx to retrieve the metadata instead.
Sending OIMs
To send an OIM, MSN Messenger will send a SOAP request to https://ows.messenger.msn.com/OimWS/oim.asmx with the sender’s email and name, the recipient’s email, each OIM’s message type and body, and an MD5 hash of an internal value sent by the service that is manipulated by the client with the MSNP11 challenge algorithm (the Application ID used in the algorithm is also specified in the SOAP request).
If everything goes well, then a SOAP reply is sent with confirmation info.
Deleting OIMs
To delete OIMs, MSN Messenger will send yet another SOAP request to https://rsi.hotmail.com/rsi/rsi.asmx with any of the OIM’s GUIDs MSN specifies to delete the corresponding OIMs. If everything is successful, a response SOAP body is sent just containing confirmation info.
Back to the Notification Server (NS), an MSG command will be sent notifying the MSN client of the deletion of an OIM.
Epilogue
That’s really about it for OIMs. It will take some time to finish, but nothing too daunting. If you think that I am just the Yahoo! guy, you thought wrong! ![]()
However, I do need to arrange time for that, and it’s not necessary of a feature to look into, so actually implementing the thing will be sought after at a later date. ![]()
