I would recommend using 7.5 or lower anyway, granted you haven’t already set up the proxy Nojus provided. By WLM 8 it starts using HTTPS for some account and contact list related actions outside of login, a few including creating groups, adding contacts, and moving contacts between groups. Since XP’s HTTPS support with Escargot (right now) is screwy even with the IE hacks, that means doing certain things on WLM will be unreliable and not sync well with the server. Just a warning.
