Where is primary
The internal memory of the phone. not the microSD
Internal storage?? Because i find mercury not
I found!!!
It says: âpassword check failedâ
the goal is to remove everything related to âMercury Messengerâ and then reinstall it
I removed everything from the main storage and from everywhere, but it doesnât work. I probably have a problem with the internet router.
try connecting with msnp15 now
same problem
hmm
It is working again, thanks for fix
Im trying âŚ
Nothing!!!
Tried testing on another device / phone?
Ok. I have a phone, but it Doesnt work, because its on the same wifi connected
you should still try
