I have msnprotocol 15 enabled but nothing!! I cant download the mercury msn app from the original topic site, because i download then the onedrive app cant open then i go in the internet browser and still nothing
And then returns to the start site.
Oh. Try this link then? http://storage.log1p.xyz/misc/im.mercury.android_build03_beta2.apk
Omg thanks i never tief this
OK cool
I suspect the app probably expects the password to be 8 characters or less (it looks your passwordâs more than that amount). If you can try to reset your password from the Escargot site so that itâs <= 8 characters and try logging in to Mercury again.
I suspect because the app is several years old and isnât optimized for newer Android versions.
Ok i try
Still nothingâŚ
The only solution I found to that, was to tile a picture. thus it is not noticed that it is repeated
I have changed my password still nothingâŚ
To six charachters
Hm. Mind telling me what version of Android you have? I guess thatâd give me a clue as to whatâs going on. Otherwise, Iâm stumped.
Android 9.
Same version I have. And Mercury works on it.
Yeah Iâm pretty much out of ideas.
I have question
In future you revive wlm 2010 too? with social network feature and videocall? When comes out wlm 2009?
uninstall / install the application again. and delete the application data in the primary memory. i also use android 9
