It just shows my profile bio. WLM 8.5. Help would be appreciated.
This question requires the knowledge of what media player you are using with this setting.
Use AIMP player: MSN "What i'm listening to" plugin for AIMP
I’m using Windows Media Player
maybe version is too modern and this msn function isn’t works in 12 or 11 verison. so, use aimp
Oh please vesecraft. Everything can be fixed ![]()
@KeyboardKrasher check if the WLM plugin in WMP is enabled and check if the “Show what i’m listening to” ticked too ![]()
