I really wanna show people what i’m listening to on spotify for some odd reason. Is there any possible way I can do this?
TReKiE
April 4, 2020, 8:05pm
2
If you use one of these:
Hello, i’m so thankful for this project that i had to contribute somehow, idk if it is already done but i’m almost finishing my own app that will post your now playing song of Spotify on Messenger psm.
Once it is authenticated an running you will be able to apply the current listening song even if it is playing on other device.
This app should be compatible with any version of MSN/WL Messenger that support the Now Playing feature, and it should run on Windows XP,Vista,7,8(.1),10.
Screenshots
Hello! Mmmm… I’m not sure, but in case if this could be possible, I’ll do it
Then you can use the Plus! (!MYMEDIA) tag in a message. You can also access it from MyCurrentMedia string in the Messenger object if you’re doing Plus! scripting.
