i used the re skype server but it closed and i can’t sign in from It now i cant use old skype
well you have no other choice bc you only have tryskype
or actually use pinto instead. (not a revival but a skype 0.97 clone)
i tried to use pinto but it gives me error
in theory it might be shutdown just like what happened to vlod
what happened to reskype and vl0d: vl0d (aka owner of reskype) gave up because in theory its some incident that happened to me and ranvir. and so tryskype decided to make vl0d give up from reskype
so tryskype’s remaining.
tryskype is in discord tbh
how to get tryskype?
its in “skype classic” discord server
find it by urself idk
Ok so I’m here after some months,I use a very cool Russian revival called Kskype,it works very well
That’s just a skin to web skype
no open it from firefox it wil work
if it have old theme-sounds so
no problem until a real revival fo ver 6-5 happens
how do you open it from firefox?
open kskype site 4rom fire fox
ohhh i thought you meant open the skype web client from there ik i have kskype
