Hello, as you may know, from the pools of the “how about a Old Yahoo! Messenger Server”
theres this guy (Wildman_Fujiami) who made a basic yahoo messenger server, informed that he
opened the server to outside connections, meaning that you can connect to the server and chat with people,
since yahoo messenger isnt aim, where you set the server from the settings and your ready to go, you need to do patching via regedit (oh no)
Anyways, to start off, heres the client download: http://www.oldversion.com/windows/download/yahoo-messenger-6-0-0-1922
after downloading and installing, close yahoo from the system tray or task manager, or whatever.
heres the (not) fun part, patching.
open regedit by your start menu or Windows+R and typing regedit, now go to
(HKEY_CURRENT_USER > SOFTWARE>yahoo> pager)
click on the pager folder icon (
then this should appear in the right:
right click
and modify, then set the value to iwarg.ddns.net and click ok, then start yahoo messenger, you can login without registering, so entering something really random will work.
well, i cant really solve problems with login, and not opening, dont even come to me, try setting compatibility.
pin this post please
