I am using messenger 8.5 and i have this issue where I cant see some of my contacts online even though they are. I tried blocking, unblocking and everything but nothing works, even though they can see me online, does anyone know how to solve it?
It’s a bug.Try uninstall and reinstall ![]()
Sure ill give that a shot, thanks
Didnt work though
Any other tips?
try installing windows live messenger 8.1
I had that before 8.5 but that didnt go smoothly either. Quite annoying.
well i dont know why this is happening so … sorry i cant help
Its okay thanks for replying anyway.
Maybe this will help
Sadly no it doesnt but thanks for the tip
It’s a bug, will “solve” itself alone with time. @anon50801480 knows this feeling.
Here’s hoping it will
Well, since you called me ![]()
I also suffer from this bug, tried several things but I could not.
The only method that worked for me was to use Mercury Messenger on your smartphone: log into your account, add the person and log back on to the PC. With me when I do this the contact is added and if online, it is shown online. Try it yourself and tell us later if it worked.
My smartphone drowned a while ago, but thanks for the tip anyway
But you can use Mercury in an Android emulator for PC. A very light that I like a lot is YouWave
Ill give it a try
I cant even find the app for it
Mercury or YouWave?
Mercury
