I’m sorry for bad English, I’m using the translator.
Escargot is open source? I would like to be server for more testing and use. I have server and fixed fiber of 300 megs. (Download and Upload) Brazil
I want to do a private test and when possible feedback.
If possible, can anyone give me guidance?
yes, Escargot is open source, and there is my guide on how to get a server running.
don’t worry, this still works.
EDIT: Creating a WLM 2009 server seems to have been broken by a recent commit to the WLM 2009 branch. If you still have an old copy of the branch, keep it. It just seems that this thread was made at the wrong time.
I initially said I wanted to do this in the form of a YouTube video but since my PC died I can’t do that, so this will be a thread instead.
[image]
This tutorial is using the Windows Command Prompt. Running it on MSYS2 or an actual distribution of Linux is beyond what I can do
Yo…
this is for Windows Live Messenger 2009 specifically, but i do believe it works with other versions regardless.
Chaziz
June 3, 2019, 10:35pm
3
wasn’t able to connect with a 8.x (from early betas to 8.5, on a unrelated note, also 2009 betas) client for some reason on my local server. however that was in feb-march.
that was in march, so it doesn’t work anymore
it works, but it was moved to master branch.
