Thanks.
when or we can download it
For future reference, the server is compatible with Yahoo! Messenger 5.5 right now. You can find that, along with other versions of Yahoo! Messenger, here: Download Old Versions of Yahoo Messenger for Windows - OldVersion.com. Then when the server is final and live, you can download and patch as needed. ![]()
(Just note that there is a weird bug with 5.5 when run on WIndows 7 where it freezes after a successful login. It may just be me, but be wary).
ok
perfect good job and good luck :PPP
what yahoo i have to download ;-;
I’d recommend Yahoo! Messenger 5.5.1237, since that is the build that I am certain will install on modern operating systems (older Yahoo! Messenger versions will most likely use a 16-bit installer, so unless you have a 32-bit OS installed, no good in that
oke thanks
You’re welcome.
I sign in with my Escargot account ?
I plan to make it so Yahoo! accounts and MSN accounts in the Escargot database are separate. So you’d have to create a Yahoo! ID specifically for Yahoo! use.
Also, I think you may be confused with something.
The Yahoo! server is a work in progress, and is not live yet. Especially since the protocol that powers Yahoo! Messenger has very little documentation, which makes server-side implementation all the more lengthy. But don’t worry, after I get conferencing and fixes done with, the server will hopefully go live.
so i can’t login in
Technically, no, since the server doesn’t exist yet. Just hang in tight, though. This rollercoaster ride will end soon.
ok
thanks ^-^
wee woo wee woo here’s the grammar police you used the wrong your/you’re
Oh shoot thanks for reminding me.
‘‘3 times’’ omg discourse
UPDATE 10
Finally got conferencing fully working! ![]()
Basically, I am finished with as much of the Yahoo! frontend as fit. I just need to refine and tweak some things, and I’ll finally update that long dead ‘feature/ymsg’ branch. ![]()
Marvelous work.
