why this error?
It’s normal. You may skip it.
but if I try to click on a contact to send a message crashed
Any Fix?
now is impossible to use MSN for this error
it works, one thing, I selected during the creation of the account the support to old versions of msn, I tried MSN 7.5 but always error connection is normal?
Can you give me the error code?
Blame @Craftplacer for making localization and @Maigol use Google Tags.
81000306
The Google tags are from @valtron’s host.
Also Craftplacer did nothing aside from supply a JSON file for the translation.
81000306
Try disabling firewall i guess
In the website code, there’s a useleess console.log() statement that prints the current language.
I believe that if I delete that the error should disappear
the firewall does not block anything, so why WLM working?
Questa è la versione 7.5 se non sbaglio… Per riparare devi andare in
C:/Programmi(x86)/Messenger e sostituire l’eseguibile con la mia fix ^^
non va lo stesso, e sto usando quella già con la patch
non è che solo l’ultima versione funziona?
