ehh i already did it long time ago lol
Microbes is another stock android lwp but its rare to find a working one
just for some android 14+ users who are struggling installing apks meant for older versions, you can bypass it using 2 apps: shizuku (Download | Shizuku) and Install With Options (Install with Options - IzzyOnDroid F-Droid Repository)
Shizuku gives root-like acess, even though it does not really root your device
Install With Options has an option where you bypass android previous sdk restrictions to forcefully install an app onto your device, just select a apk you want to install and it should work like that
keep in mind not all live wallpapers in lwp collection works
(some games or app, ex: cookie run kingdom, doesn’t like shizuku for some reason, so if you want to play the game then uninstall shizuku, only after you install an apk)
You also have to take into account the processor architecture the APK was built for. For example, how you seem to be unable to install x86 APKs on an ARM Android Build or device
I actually have an apk modifier I used to increase the target sdk so I can download these lwps.
nice idea
but they would break
It could also be the matter of architectures / ABIs (?)
Some APKs may be compiled for arm, some could be for arm64 and others could be for X86. In my experience I’ve never had an arm64 or x86 APK work. To be expected of course.
(It would act like normal but then the install would instantly fail)
