I’m on Motorola whereas they’re on Samsung though. not sure if that changes it lololol
I have a tip for you. For Android Live Wallpapers, Holo Spiral, Magic Smoke, And Music Visualization Wallpapers, get the 4.4.4-90 versions of those apks. They’re usually the best version of those live wallpapers you can find.
do you have a link to a download page?? I’m really bad at finding apks ![]()
Sorry heres a better music visualization wallpapers apk: https://xdaforums.com/attachments/idk-apk.5510733/
So how did you get Water to work? I tried the APK and Water still crashes
which apk did u use? both mine and mstrystarr’s worked (not without bugs and horrible image stretching
mine also seems to struggle on finding where u pressed. probably because of the size of my screen)
every apk i have found so far (including MystryStarr’s) yields the same result. I am running Android 9
It was from a guy that fixed water and polar clock in a xda forums post who is now a deleted member where someone was sharing a music visualization wallpapers apk.
I hope someone can fix magic smoke
Could you provide a link? Hopefully a web archive exists
Thank you! This works!
seeing other people that are into old android lwps makes me happy lol
(fyi I’m the person who posted music viz lwp extension on xda)
I wish they still made live wallpapers like they used to ![]()
like imagine material you style music visualisation…
yk there are a lot of other awesome lwps made in the past, many of them are longer avaliable on play store
Let’s go apk hunting!
