Classic Android Project - Live Wallpapers
So i’m working a project to combine “old android” with “new android”
Currently I am working on the Live Wallpapers as those are no longer included in newer android versions. I have managed to resign some Live wallpaper packages and have gotten them working on Android 9.0. Here are said live wallpapers:
My firmware is a stock Motorola android 9.0 ROM (Though heavily modified by me, google-less, bloat-less, has fully working LineageOS (And some AOSP) applications
Music Visualization Wallpapers (Spectrum, Waveform, VU and both) (Self explanatory in what they do…)
Black Hole (stars spin around the center glow)
Bubbles (Reacts to touch, bubbles avoid where the finger is touching.)
Grass (Time changes, grass moves as if there’s a breeze. Reacts to launcher page switches. Day and Sunrise/sunset background act odd. Happens with the night background too, but it’s less visible)
Magic Smoke (Works but color can’t be changed as it will crash when attempting to load the configuration menu)
Nexus
(Works just fine, however the background has trouble displaying on larger displays/resolutions. The performance cap also shows on newer devices. A different variant on nexus (For a Sony Device) is hosted on APKMirror. It has not got the cap and the different background scales correctly. Reacts to touches and page switches)
Phase Beam (Works exactly how it used to, no touch responsiveness)
Update, by patching a few things in the manifest and classes.dex, Polar Clock now works!
nice! can you make android water live wallpaper? like on image because when I try to run it up my device it crashes and doesn’t set the wallpaper :frowning:
also I have question if I could use your modified android live wallpapers for android 4.2 icons pack?
this project looks cool. i hope it will be ported to android 14!
What is the launcher you’re using
Trebutchet, the launcher that is on LineageOS
Unfortunately this isn’t possible. Water contains scripts that are deprecated on newer android versions.
Would you like me to send an apk? (Not all is included as android has the others as separate packages)
Well add the dead scripts into the app itself
foaming from the fucking mouth right now
I’m begging you send me the apks for those wallpapers ESPECIALLY the red one omfg pleasssseee
Can you send me the spectrum APK?
I have an apk with spectrum, waveform and both, plus some others I think. grass and galaxy do not work.
Android Live Wallpapers_rc1.apk (2.6 MB)
tell me if it’s not the right file :stuck_out_tongue: I forget to label them correctly :blush:
That animated wallpaper is also on my tablet with Android 4.4.2
For everyone nagging for the APKs:
My files are too much of a mess so i’m trying to find the APKs
How did you customized navigation buttons?
“Custom Navigation Bar” by Paphonb. It requires adb or shizuku in a non rooted device. I know it works on Android 9, but unsure about newer versions
Looking pretty cool so far! I have all of these working on my phone except for Magic Smoke.
What did you do to get water working?
it works on mine thanks to some guy on xda forums although it does not work on tall displays… along with galaxy, black hole and grass. I got a grass free app from Google play and I don’t use galaxy. water works but not well at all on my screen. it might work better on older phones though…
