in the site named Sherv, i founded this “stealing tool” which you can use emoticons, winks and Display Pics from other users, so you can be like “all your msn things are mine!!!” so then i installed CEDP Stealer, that app needed MSN Messenger of course ![]()
CEDP Stealer:
I was running MSN Messenger, so then i tired to test the app, so then i pressed Scan and nothing showed, but wait! i have contacts, so why it doesnt work? even the display pictures doesnt shows. it says 0 Files founded in 0 or 0,001, totalling 0 MegaBytes,
someone should modify this app so it can connect to the escargot server instand, or maybe not
