Yet another MSN revival
Can I have one?
could i also get a key too? thanks in advance
A key has been sent to everyone!
@SevenTheGamingKitty I could not PM you though so I wasn’t able to send you one
Thank you!!!
First of all,
congratulations for your project is looks stunning.
second and most heartbroken –>
I wished to met you / be here on the forum
when the originals servers where up and also when, i could still login on the originals login.live. com thanks to my msn cache—>
I’m on the only human in the World with a original WLM 2012 back from the day ( i think) - Messenger Discussion - MessengerGeek
read the above for info and also find the attached files.
maybe they help you :slight_smile:
wishing the best to you.
I have pretty much everything(? I think) reimplemented MSNP21-wise so the files you’re talking about won’t be helpful, but thanks though!
you’re welcome. my original dream was to somehow make a bridge between original server only for the login side - and the the custom servers for the rest. but now its never gonna happen cause the msn-server.php see above my link at my post not working anymore since may – it has to do with the skype shutdown–
Using official Microsoft servers would be practically impossible with a custom server, even just for the login side
Hello, i’m having issues with WLM ‘12. Whenever i try to log in, i get the password incorrect error (error code: 80048821) which is the same issue i have ran into while trying to use wlm ‘12 with crosstalk. do you know how to fix this? i’m on windows 7 btw
EDIT: im so stupid i just realized we have to use kring.im at the end ;-;
I just logged in and WOAH THIS IS SO COOL !!! just added you btw :slight_smile:
add me! alposaurus@kring.im
EDIT: SORRY FOR THE TYPOS IM EXCITED
Can I get a key as well?
Sent
Microsoft taking down the original messengerclear.live.com authentication realm for RST2(Which causes Windows Live Messenger 2009 and later to break) had nothing to do with Skype shutting down. It was just part of Microsoft’s plan to shut down legacy Authentication methods such as (RST(Request Security Token V1), old service policies and old whitelisted realms(such as messengerclear.live.com)).
Also don’t see why you need the original login.live.com server any more when you got feature complete revivals instead of some bridge using cached Address Book data.
You can add me at avenger@kring.im
oh ok.
oh , why would be so difficult? just from curiosity :slight_smile:
Ryder explained why, also even if you did you wouldn’t have your OG contacts anyways so I don’t see the purpose
oh ok. by the way the msnserver.php stopped working when skype shutdown thats why i assumed that they were connected. anyway one last question. is there msn 1.0 will be supported in the future?
Maybe, I don’t know, but MSN 1.0 and MSN 2.0 are like pretty much the same tbh so
Can i get key?
