Yet another MSN revival
May i have the key?
Most interesting…
How did you got it working
Zefie Minisrv on 4.3 TV2 firmware with modified Tweener nodejs proxy. Its very complicated.
issue: i cant download messenger
Unless something else is going on, in most cases this is the result of an unfortunate feature of the installer which tries to automatically download the language files for the language you have Windows set to, in addition to what’s included in the installer.
There’s a couple of workarounds, but assuming you don’t want to go hunting down your Windows’ language installer, the easiest method is to disable the network adapter before running the setup, and then re-enable it when it’s finished. Since the Microsoft server no longer has the language files to download, it fails installing them.
I suspect you probably already know how to do that, but if not, bring up the Start menu, type ncpa.cpl, wait until it finds a match, and then click on it. When the Network Connections window opens, right-click your enabled/active network adapter, and choose the Disable from the menu. Once that’s done, run Messenger setup, and when that’s done, return to the Network Connections window, right-click the adapter again and choose Enable. That should be it.
the problem was that i didnt have space and it installed successfully when i freed up some space
Can I have a key?
Hi, I’m interested in Kring, and the Windows Live Messenger 2011/2012 theme. I really want to relive those days, since Kring has more features than Crosstalk, which is how I got here. I have a Windows 7 PC. How can I get an invite code?:blush:
you ask for one :slight_smile:
how do i get a invite?
the comment right above you has the answer
can i get an invite code please? :3
Kring has started merging One Live ID accounts to your Kring accounts.
new email just in case: mammothavenger@kring.im
I finally got a Kring account thanks to the One Live partnership.
Feel free to add me!
nova-galaxium@kring.im
