Yet another MSN revival
Can I get an invite code?
Yes, you just need to get a key from me if you wanna get in for now
Sent
Could I trouble you for a key? It looks really interesting.
I have sent you one
any change to add support in the future for msn messenger for android?
add me alan98@kring.im!
It is already supported if you mean mercury messenger… Someone just needs to patch it, I don’t personally use Android and I’ve never messed with Android APKs so no idea on how to patch it myself
excuse me do you have a key i can use?
Sent
Hello! I discovered this since yesterday and it really looks awesome!! And as other people are asking for it, could I have a key that I can use for this, please? ^^
Sent
I’ve made an account now! …as already mentioned though, I’m probably gonna have a distinct lack of contacts…
login err
Did you patch it with kpatcher? Also is your OS fully up to date?
By the way, you don’t need a VM on an older OS to try this out, this works on Windows 10/11 as well since it “emulates” the authentication stuff when patched instead of using the actual ones on the system
fixed
Can I get one account
I’ve sent you a key
Will Kring have it’s own Plus! Sound Server?
