Hi,
Does anyone on here happen to have the UI sound files for the Fall 2009 and Fall 2010 Xbox 360 dashboards? I’m not looking for the startup sound, as I have that already. I’m just looking for the user interface sounds (navigation, select, guide menu etc).
Thanks in advance.
Hi, I don’t have the sounds for the Xbox 360 2009/2010 dashboard sounds, but I might try to look for it.
I found the NXE sounds I was looking for. The NXE update actually came out in 2008, not 2009. Sorry for that little mistake ![]()
I’m still looking for the 2010 dashboard sounds, though.
