I just want to know if i’m the only one in this situation…
Having the same issue as you are as well as 7.5. Not sure what could be the issue since I tried doing with firewall.
I have the same problem too, with the same version (8.5)
Can login now
Try again.
For Me, I spammed Enter on login button and then click login button again and it’s work.
(it’s only works on XP for some reason).’
You can try download escargot patched msn.
For me 7.5 is working fine ![]()
P.S When MSN gives me an error i always think: “Oh sh-t microsoft has destroyed escargot!
