I suspect you’ve done more with this since posting, but even if you have gotten farther, with the symptoms demonstrated I’d really encourage you to do a memory test. Assuming you have a working Windows install based on what you said, searching for memory diagnostic in the start menu will run the test. Otherwise, you can search up how to make a memtest86 usb key easily.
