Why does it open two tabs when i log into wlm 2009 escargot?
is it normal that for me, on windows 10, i login to wlm 2009 and then it opens two of the same tab in the taskbar? i keep the app in my taskbar. but is this normal? ik this sounds dumb
Pretty sure you meant windows, if one shows the profile and the other the contact list, yeah, that’s intentional. That’s just how microsoft programmed it for whatever reason.
