Concept is: You enter a command on either both WLM and Discord and you get the same result. So you can contact the same bot on Windows Live Messenger or Discord.
So now; I had a plugin platform for my Discord bot (CraftBot) where people can code plugin DLLs and I could add them resulting in to more commands available. In the end nobody did that
except me writing the base commands module.
So what I wanna pitch to you is a bot that works on both WLM and Discord and where you can code commands for it.
I might make it open source as well.
Let me know what you think about it.
So, should I work on that project; building a framework etc. ?
In the meanwhile Iโm trying to make MsnpSharp work with Escargot.
Considering also that I aiming to do new accounts (for WLM and Discord); how should I name it
And does anybody have suggestions which script interpreters (e.g. JS, Lua), I should include in the framework (to make plugins with multiple programming languages)?
Lua is nice, but if you can use PAWN,it is C like, easy to do, open source.
I still need a name to start the project.
UBP
Tekstas seems unclear, is it a complete sentence?
[OK](javascript:
Does anyone have an idea for a logo?
