does not matter if you are on a vm or real hardware post a pic of what your about os looks like mine is this right now
ok, fine calm down
I’m the only here that uses Windows 10 2004?
wait, 2004? Is that the newest? If so, luck for ya then.
yes
I upgraded using Media Upgrader tool for Windows 10, but, in order to work, you need to activate a thing to microsoft collect all of informations, in the OOBE, is in order to select Full, and, yes, I already tried make with basic informations, but, it doens’t work, and give a error, saying that No action is needed
Oh, ok. It’s very lucky for you to install 2004.
prerelease version
Because last build is 7601
You mean RTM :v
yes
you use win 7 in 2020…
why not?
it’s too old. install 8.1 or 10
