I would like to inform the Escargot Users in case they dont know, that voice clips are working on all versions of MSN clients that support this feature.
alexisnik199111
Official Escargot Tester.
alexisnik199111
They don’t work for me it says “An error happened while connecting to the server”
Do you have 7.5 patched???
Mmmm, nope. I have 7.0 because 7.5 won’t let me sign in
https://escargot.log1p.xyz/#downloads
go there find your native language and downlaod 7.5 pre-patched,
did you uninstall your 7.0 and then install 7.5??
yes, I did that
try to make a password reset → Forgot Password | Escargot | MSN Messenger and Windows Live Messenger
are you sure youre typing right???
Yes, I’m completely sure I typed the password correctly. And even I tested 7.5 in a Virtual Machine with Windows XP, where it worked.
try a password reset in the link i wrote
Try to type your email address in lower case… your first “C” is capitalized.
Downlaod this tool and copy/paste the log here: https://gitlab.com/valtron/msn-server/uploads/6f29cda98eeb051c5d789babd5fa70e6/Escargot-Troubleshooter-1.2.zip
vĂdeo calling Works too ( with 7.5 Works )
