Ok since Messenger Geek can be change to lithuanian everytime i want to translate a text from spanish or other non english language it give a 500 internal error…
Same with hungarian
same with Greek
portuguese is working fine
Polish is fine.
I’ve done some debugging of the translation plugin that powers this. The actual error message behind the 500 error is: This language is not supported by the translator, and in the plugin code that is correct, Lithuanian, Hungarian and Greek do not appear in the supported list.
However, I have no idea why they wouldn’t be in the supported list as they are supported by the API. I’m going to see what needs to be done to get them (and hopefully other missing ones) added.
