What I’m doing rn are just changes to MSN Explorer’s authentication services so that it can log in without M$’ servers barring the connections from older clients. And I assume that MSN Explorer has some sort of MUI interface, anyways, so that’s not much of a concern.
MUI, as in Multilingual User Interface?
Yes.
according to my “research”, the choices for MUI content is:
- Optional Extension
- xml
- magical web thing
If your speaking MS:
- xml
- xml
- rewrite the program in that language
and msn explorer looks so cool!!!
Any new updates?
4 MONTHS LATER
body seems
I’m pretty much stumped until I can get some good debugging tools and a good enough decompiler to reverse engineer subroutines. This is for msnmetal.dll, since I assume that helps MSN Explorer with the UI and login frontend stuff.
will there be a way to get the installer to work. on my computer it says “Check your internet connection”
What installer are you using, and what version of MSN Explorer does it install?
idk. but i’ll upload the files to dropbox
it also contains an msn messenger 6.0 installer
here is the link: Dropbox - MSN - Simplify your life
what version of msn explorer is it
how is the progress of MSN explorer?
Unfortunately, as I stated to someone else, I’m completely stuck until I get proper debugging tools, which are really expensive and aren’t worth pirating, anyway.
okay
yeah i just saw a few pics of what MSN Explorer looks like, and i really dig it. It’d be awesome to use (In my opinion), cause you could edit some of the things, via modding like adding in a spotify player function (or something) and stuff. Also what software do you need to get that isn’t worth pirating?
Also it’d be cool to use this as a AIO program cause you could implement the messenger client, E-Mail clients, and many more on the site, making it super useful for having everything in one place.
what’s that addchild.jpg and cn_child.gif? was it some kind of feature?
