Why not make an installer of MSN 5.1.0715 prepatched?
I will made both, but first I have to install Installshield so I can make installer.
Edit: I used ClickTeam installer instead. and trying to get both patch working
I going to modify msgslang.dll to Get English Language on Terra Messenger.
Here is the screenshot:
Main Login screen:
Contact Screen
_**DOWNLOAD LINK (BETA): Dropbox - Terra Messenger English BETA Pre-Patched.rar - Simplify your life
Notice that download link is updated daily, sometime weekly
You can use Resource Hacker to modify one, and using Google Translate to translate some text to english.
NOTE: THIS IS STILL IN DEVELOPMENT, THE PROJECT WASN’T COMPLETE YET!
Chat Screenshot:
Why can’t you just copy the dll from english MSN 5.1 and then put it there?
Good luck with translation ![]()
Well, I copy one in MSN 4.7 and the UI broken.
So I have to use Resource Hacker to translate all of it.
BONUS: Messenger Plus! Also work with Terra Messenger.
I’m still working from translating Terra Messenger.
Yeah, Actually MSN 1.0-4.7 account works with MSN 5 too.
i might translate it to hungarian but first i need a safe download
Well, You can use my own patched link.
I put it on Google Drive and it’s original.
NOTE: You have to unzip at Terra Messenger Directory.
You need Resource Hacker to modifying all.
The file we need to translate is just msgslang.dll
EDIT: I’m working with HL2 maps, so I can’t modify Terra Messenger English language at same time.
Here is a link you want to continue edit: Download Early Translated msgslang.dll
Have fun from editing that file
Note: the english language ID is 1033.
I also changing Windows Messenger msgslang.dll to change .NET service (dialog) to Escargot MSN Service.
And Fixing UI bugs like text got like this:
Too bad that Terra Messenger just had problem for me (Running Windows 7, Also same for 10 but XP works fine):
Back again but Let’s see if it can Run on Windows 10…
(yes, a bump)
Edit: The unpatched Installer can’t install it due to 64-bit Windows.
So I have to use another way is Download pre-patched version (DOESN’T WORK either)
I think it’s only works on Windows 32-bit and must be XP Compatibility mode.
Edit: The Manifest file is not supported on newer windows, so You need to copy from WLM 8 Manifest code and some info by using Resource Hacker.
Nice bump
the best bump in the world
i’ve saw bumps that were 6 month long.
*after 6 months
Idea for making a english Terra Messenger.
Dump all of Terra’s assets and put these Terra assets on a copy of 5.1.0638.
(bump)
I going to fix Terra Messenger so It’s can run on Windows 7 and newer.
EDIT: It’s seem like it’s not running, it’s running then close, maybe it’s only for 32-bit only.
I modified Manifest to remove Side-by-side error.
It’s seem like the .dll was broken.
I also tested Windows Messenger 6.1 dll from Windows Longhorn 4074 and still not working.
It’s just Windows Messenger with different graphics.
Yeah that was what i said for the Terra Messenger problem.
