This is an emoticon I put together from a larger gif in 2010, it uses two emoticons that you put down side by side, but it works well.
Together:
Separate:
Together:
Separate:
Wait, so you just birthed 2 forum category’s based on Customization? Whats next? Display Pictures?
You already got that covered? whats actually next then?
Also, for MSN Messenger users: Use a Messenger Plus! Plugin called StuffPlug-NG. that Plugin allows custom Emoticon sizes.
Link?
Look I did it
And here its the Sonic Mania edition:
